- Mura
The Hondata Coil Pack Retrofit (CPR) allows the use of 'coil on plug' individual ignition coils on engines with distributor based ignition systems (D, B, F and H series Honda engines). It does this by replacing the stock coil and ignition with an electronic circuit which can drive igniter type individual ignition coils, such as used on later model Honda engines. A Hondata S300 system is required.
- Price is $395.
- Price is $395.
- Support1
Якась не ридна мова....
В смысле, Дим напиши про продукт по-русски...
- RaZVaL
очень интересно!!! - а чем управляется это дело?
п.с. вопрос снял - управляется S300
вот фото похоже
п.с. почитать можно здесь
http://www.honda-tech.com/showthread.php?p=45032248
фотки удалил чтоб в заблуждение не вводить.
вот фото похоже
What does the Hondata CDR come with?
The Hondata CPR comes with a wiring harness for your coil packs, a coil pack controller and fly leads for connecting to your distributor and ECU. The CPR is typically positioned next to the ECU inside the car.
Benefits
* More spark energy than a single coil, allowing a larger plug gap and fewer misfires.
* Individual coils are more durable and less likely to fail than the stock igniter and coil.
* No exposed plug leads results in less interference to other electronics on the vehicle.
* Additionally, the Coil Pack Retrofit can drive a CDI controller if desired.
Requirements
* Hondata S300 system (not included).
* 4 x coils, Honda part number 30520-PVF-A01 (approx $60 retail and not included)
Optional parts
* 4 x coil seals, Honda part number 30522-RNA-A01 (approx $19 retail)
These coil seals provide a tighter fit than those supplied with the 30520-PVF-A01 coils.
Notes
* Resistor plugs must be used.
* The coils require a method of retention. B16A, B18C & F22A engines may use the stock plug cover. Other engines require an alternative method of coil retention (not supplied).
* This is a race product. Cranking times may be increased over a stock ignition set up.
* For detailed installation instructions click here.
FAQ
- Can I remove the distributor?
No. It is needed for the timing signals. See the CPR help file for more details.
CDI
- The Coil Pack Retrofit can be used with capacitive discharge ignition systems, such as M&W Pro-14, Autronic 500R or Motec 41011. Note that a CDI controller must be used - the Coil Pack Retrofit will not drive capacitive coils directly.
The CDI controller will be triggered from the Coil Pack Retrofit coil trigger outputs. The Coil Pack Retrofit produces a rising edge trigger for the coil packs, so the CDI controller should be configured to use a rising edge trigger.
Does this sytem work with any other engine management?
NOT AT THIS TIME. At this time ONLY hondata s300 works with it.
"The S300 needs to output a synchronization signal to the coil driver."
The system communicates with the ALTC (alternator control) output.
Последний раз редактировалось RaZVaL 10 апр 2011, Вс 9:49, всего редактировалось 1 раз.
Три заповеди:
Верь знакам - три.
Объясните мне пожалуйста, зачем усложнять систему до такого состояния?
Особенно с учётом того, что трамблёр где болтался там и болтается...
В чём настолько атомное приемущество отдельных катушек?
ЖРАТЬ СПАТЬ ШЕРШЕНЬ!!!
- Mura
rmn писал(а):Любопытно.
чую что катушки от стрима и цивика д17 (30520-PVF-A01 ) на разборах скоро станут дефициом))))))
На каком уровне мощности это насущная необходимость?
500+
- BlackPerson
на фотке вроде атмо мотор)
A4 2.0 quattro
катался ны ТЫЧе)
A4 2.0 quattro
катался ны ТЫЧе)
- Mura
по русскиSupport1 писал(а):Якась не ридна мова....
http://www.r2racing.ru/novosti-lenta/ho ... t-cpr.html
Я собираюсь в ближайшем будущем датчик распреда от Ниссана адаптировать, чтоб избавиться от трамблера вобще. Меня тут народ пинает что хочет на другие моторы хондамозги ставить, а трамблер ставить не хотят.
- AntonKuzmin
- Машина: LL
хондата пытается догнать АЕМ?
Вот тебе и пожалуйста.
rmn
это правильный пример того, когда вырученные деньги от продажи продукта идут на поддержание и расширения функционала немолодой платформы.AntonKuzmin писал(а):хондата пытается догнать АЕМ?
еще-б буст контрол к ждм мозгам прилепили-б)))))))
- talyan
так она только со спаренными работает или пофигу какие? управляет минусом?
просто на современных авто много где управление +5в
Honda Integra DC2 K20
Honda Integra DB8
Honda Integra DB8
- talyan
так а положение калена так и будет с трамлера? мош они сделают какойнить модуль штоб трамблер балдой не висел на башке
Honda Integra DB8
Honda Integra DB8
- ТУПЕР
на фотке модуль, и провод к катушкам...talyan писал(а):так а положение калена так и будет с трамлера? мош они сделают какойнить модуль штоб трамблер балдой не висел на башке
я так понимаю этот модуль должен цепляться к фишкам с трамблера ... чтобы блать данные с датчиков? но их там что-то не видно ...
Дим когда реально можно будет купить этот девайс? готов быть первым на очереди ...
- Mura
нигде про спаренные вроде не пишутtalyan писал(а):так она только со спаренными работает или пофигу какие? управляет минусом?
можно обычные хондовские катушки с встроенным игнитором по минусу
- Mura
в средине апреля вродеТУПЕР писал(а): Дим когда реально можно будет купить этот девайс? готов быть первым на очереди ...
- ТУПЕР
К ЭТОМУ ДЕВАЙСУ ЧТО ЕЩЕ НАДО ЧТОБЫ ПОСТАВИТЬ И РАБОТАЛО ВСЕ?Mura писал(а):в средине апреля вродеТУПЕР писал(а): Дим когда реально можно будет купить этот девайс? готов быть первым на очереди ...
КАТУШКИ - 4 ШТ И ВСЕ?
а мне на пару дней погонять кто нить даст... может чего интересного сделаем.. а то ценник конский за тупой драйвер...
7-926-477-68-44
Сейчас этот форум просматривают: Dot [Bot] и 15 гостей
