Lockly-Lynx
Машина: delSol
Сообщение 12 авг 2010, Чт 21:39
http://www.jetchip.com/shop/shopdisplay ... es&sppp=10
Part #: 65001
The JET Performance Import Computer Upgrade Package is the solution to performance tuning import and domestic sport compact vehicles. Import computers do not have computer chips that are easily removed, making it necessary for JET engineers to either reprogram the vehicle’s existing chip or remove and replace the chip by desoldering it from the circuit board. The kit provides you with all the materials required to safely send your vehicle computer to JET’s lab for a high performance software upgrade. Once we receive your ECU it will be programmed according to the information you provide on the vehicle specification sheet to optimize performance and mileage to match your specific modifications. JET's exclusive Dynamic Spectrum Tuning provides optimal performance across the entire power band-not just at full throttle. Programming includes extensive modification to air/fuel ratios, ignition advance and boost pressures for turbo applications.
PRICE: US$329.00
Jet 65001 Import ECU Upgrade Kit
Fits 1992-2003, Acura The computers in most imported vehicles don't have chips that can be easily removed and replaced. The solution is this Import Computer Upgrade Package from Jet Performance. You get everything you need to safely send the computer from your vehicle to Jet's own computer lab for a high performance software upgrade. Your ECU will be reprogrammed according to the information you provide on the specification sheet that's included in the kit. This includes extensive modifications to the air/fuel ratio, ignition advance curves, and boost levels in turbocharged applications. Jet's exclusive Dynamic Spectrum Tuning will provide the best solution across the entire power band, not just at full throttle. Jet 65001 Import ECU Upgrade Kit • Dynamic Spectrum Tuning for optimum performance across the power band
• Everything you need to safely send your ECU to Jet's lab
• Full specification sheet included
• Your vehicle's ECU reprogrammed to your specifications
• Get optimum performance and mileage
• Upgrades include air/fuel ratio, ignition advance, and turbo boost
работал в паре с d16y8
15 т.р.
Последний раз редактировалось Lockly-Lynx 15 авг 2010, Вс 11:42, всего редактировалось 2 раза.
Опустошитель
Сообщение 13 авг 2010, Пт 12:43
насмешил :D
HONDA INTEGRA DB8 B18C (SPOON,HKS,TODA,MUGEN,APEXI,SKUNK2,ACL,WIESCO,MOMO)
neon626
Сообщение 13 авг 2010, Пт 18:16
3т.руб
Lockly-Lynx
Машина: delSol
Сообщение 13 авг 2010, Пт 22:46
Опустошитель писал(а):насмешил :D
:wink:
долгих лет жизни
solobaric
Машина: Honda Accord CL9 typeS
Сообщение 14 авг 2010, Сб 0:35
мнда............ :wink: --- удачи
Музыка дороже денег!
Сivic EG3 B20vtec spec 96 продан - продан :(
CR-V RD-1 B20--chipOBD-1- продан
Accord CL9 type-S
Lockly-Lynx
Машина: delSol
Сообщение 14 авг 2010, Сб 9:19
solobaric писал(а):мнда............ :wink: --- удачи
и чё мнда
проходил мимо решил отметиться, как собачка
Пипл вы если чё хотите сказать говорите-спрашивайте, че не так , что смущает, где исправить
да и цена не на камне выбита.
я сабж не для смеха и хмыканья создавал, купил-продал не занимаюсь поэтому мог и не так че написать
про 3рубля - я чет ни разу не видел таких цен за ecu
Опустошитель
Сообщение 14 авг 2010, Сб 10:31
и чё мнда
в том то и дело что этот мозг дороже 5т.р не стоит...т.к это сток мозг просто чип воткнули.А чип стоит с прошивкой 30$ эт самый дорогой.
Lockly-Lynx
Машина: delSol
Сообщение 14 авг 2010, Сб 14:52
Опустошитель писал(а):]в том то и дело что этот мозг дороже 5т.р не стоит...т.к это сток мозг просто чип воткнули.А чип стоит с прошивкой 30$ эт самый дорогой.
Вот это уже конструктивно, и у меня есть что сказать
Да мозг я встречал по 5 руб., но это минимум! Себе например когда искал нашел р30 за 6.
далее
чипы бывают разные и результат тоже разный
сколько только тем про настройку отсройку, детонации ит.д.
Ссылку на родной сайт я специально дал
цена 329$
я конечно понимаю что в России живет лучшая и умнейшая часть человечества :wink:
но там технология такая
снимаешь мозг отправляешь в студию там его чипуют как надо, ставят пломбы и отправляют назад,
что и проделал бывший хозяин из Гамбурга
ну и на закуску график
MF
повелитель молдавского втека
Сообщение 14 авг 2010, Сб 19:38
р28 обд2? :shock:
по теме р28 стоит 3к,р72 вон в соседней ветке за 3к тоже продают
По сути мозг только нужен, все эти чипы до жопы. Все равно надо прошивку под свой мотор настраивать а не чужим пользоваться
2024 Li L6 Pro
Lockly-Lynx
Машина: delSol
Сообщение 14 авг 2010, Сб 20:46
MF писал(а):р28 обд2? :shock:
что-бы не было " :shock: "
это раз
купить мозги за дешман в которых "умельцы" паяльником уже натыкали как в престарелую проститутку, труда не составляет
это два
MF
Сообщение 15 авг 2010, Вс 7:21
Lockly-Lynx писал(а): что-бы не было " :shock: "
это раз
это два
Ну тут умничать не надо. У хонды всегда были исключения даже обд2а мозги на обд1 проводке.
Но про р28 обд2 впервые слышу. С какой машины этот мозг
2024 Li L6 Pro
Lockly-Lynx
Машина: delSol
Сообщение 15 авг 2010, Вс 11:49
стоял на моей
CIVIC CR-X III 1997года
мотор d16y8
125-138пони
Lockly-Lynx
Машина: delSol
Сообщение 25 авг 2010, Ср 14:48
energy13 писал(а):а чо себе на ставишь?
у меня теперь s300 будет на b20
Lockly-Lynx
Машина: delSol
Сообщение 25 авг 2010, Ср 14:53
из упряжки освободился и готов к новой инсталяции
редкий коллектор
мозг + выпуск 18 рублей, торг в личку
отдельно 5 рублей
Последний раз редактировалось Lockly-Lynx 25 авг 2010, Ср 15:22, всего редактировалось 1 раз.
Lockly-Lynx
Машина: delSol
Сообщение 25 авг 2010, Ср 16:12
energy13 писал(а):мля чо это за колектор такой?)))))))))))))))))))))))))
а вот так
Lockly-Lynx
Машина: delSol
Сообщение 08 сен 2010, Ср 22:54
сабж в резерве
и
есть p28 чистый обд2а за семь рублей
Сейчас этот форум просматривают: нет зарегистрированных пользователей и 60 гостей
