- Azazel
Прошу не пинать... читал почти все темы на форуме, но ничего не понял...
объясните на пальцах куда подключить два провода к мозгу, что бы лямбда давала ему информацию и он подстраивался сам? машина RSX рестайл...
A1 -Knock Sensor(Red/Blue)
A2 -IGP2 (Ylw/Blk)
A3 -IGP1 (Ylw/Blk)
A4 -PG2 (Blk)
A5 -PG1 (Blk)
A6 -CMP.B (Grn)
A7 -CKP (Blue)
A8 -LG2 (Brn/Ylw)
A9 -LG1 (Brn/Ylw)
A10 -AFSHTC (Blk/Wht)
A11 -IMRC (Red/Blue)
A12 -IAC (Blk/Red)
A13 -IGPLS4 (Brn)
A14 -IGPLS3 (Wht/Blue)
A15 -IGPLS2 (Blue/Red)
A16 -IGPLS1 (Ylw/Grn)
A18 -NC Spd Snsr(Blue)
A19 -CMP.A (Blu/Wht)
A20 -VCC2 (Ylw/Blue)
A21 -VCC1 (Ylw/Red)
A23 -SG2 (Grn/Ylw)
A24 -SG1 (Grn/wht)
A28 -AFS.-(Red/Ylw)
A29 -TPS (Red/Blk)
A30 -MAP (Grn/Red)
A31 -AFS.+(Red)
B1 -VTC (Blue/Wht)
B2 -INJ4 (Ylw)
B3 -INJ3 (Blue)
B4 -INJ2 (Red)
B5 -INJ1 (Brn)
B6 -VTS (Grn/Ylw)
B8 -ECT (Red/Wht)
B10 -ALTL (Wht/Blue)
B11 -VTPSW(Blue/Blk)
B13 -ALTF (Wht/Red)
B17 -IAT (Red/Ylw)
B18 -ALTC (Wht/Grn)
B21 -PCS (Ylw/Blue)
B22 -IMRCVPS(Red/Ylw)
E2 -RVS (Yel/Red)
E3 -LG3 (Brn/Ylw)
E4 -SG3 (Pink)
E5 -VCC3 (Ylw/Blue)
E7 -MRLY (Red/Ylw)
E8 -AFSHTRC (Orn)
E9 -IG1 (Blk/Ylw)
E12 -FANC (Grn/Wht)
E13 -SEFMJ(Ylw)
E14 -FTP (Lt Grn)
E15 -ELD (Grn/Red)
E16 -PSPSW(Lt grn/Blk)
E17 -IMOFPR(Grn/Ylw)
E18 -ACC (Red)
E19 -VSV (Lt Grn/Red)
E20 -SHO2S(Wht/Red)
E21 -SO2SHTC(Blk/Wht)
E22 -BKSW (Wht/Blk)
E23 -K.Line(Lt Blue)
E25 -NEP (Blue)
E26 -VSSOUT(Blue/Wht)
E27 -IMOCD(Red/Blue)
E29 -SCS (Brn)
E30 -WEN (Red/Wht)
E31 -MIL (Grn/Orn)
A2 -IGP2 (Ylw/Blk)
A3 -IGP1 (Ylw/Blk)
A4 -PG2 (Blk)
A5 -PG1 (Blk)
A6 -CMP.B (Grn)
A7 -CKP (Blue)
A8 -LG2 (Brn/Ylw)
A9 -LG1 (Brn/Ylw)
A12 -IAC (Blk/Red)
A13 -IGPLS4 (Brn)
A21 -VCC1 (Ylw/Red)
A23 -SG2 (Grn/Ylw)
A24 -SG1 (Grn/wht)
A28 -AFS.-(Red/Ylw)
A29 -TPS (Red/Blk)
A30 -MAP (Grn/Red)
A31 -AFS.+(Red)
B1 -VTC (Blue/Wht)
B2 -INJ4 (Ylw)
B3 -INJ3 (Blue)
B4 -INJ2 (Red)
B5 -INJ1 (Brn)
B6 -VTS (Grn/Ylw)
B8 -ECT (Red/Wht)
B13 -ALTF (Wht/Red)
B17 -IAT (Red/Ylw)
B18 -ALTC (Wht/Grn)
B21 -PCS (Ylw/Blue)
E2 -RVS (Yel/Red)
E3 -LG3 (Brn/Ylw)
E4 -SG3 (Pink)
E5 -VCC3 (Ylw/Blue)
E7 -MRLY (Red/Ylw)
E8 -AFSHTRC (Orn)
E9 -IG1 (Blk/Ylw)
E12 -FANC (Grn/Wht)
E13 -SEFMJ(Ylw)
E14 -FTP (Lt Grn)
E15 -ELD (Grn/Red)
E18 -ACC (Red)
E20 -SHO2S(Wht/Red)
E22 -BKSW (Wht/Blk)
E25 -NEP (Blue)
E29 -SCS (Brn)
E30 -WEN (Red/Wht)
E31 -MIL (Grn/Orn)
подключать один провод - белый.
E15 -ELD (Grn/Red)
E15 -ELD (Grn/Red)
- sniper
Подстраивать Аем лямда тебе не будет. Это фукцыя С-трим так и остаёться за стоковой лямдой. Фукцыя е15 елд нужна для того чтобы показывать только дисплейное показания лямды в даталогах. Так же уже давно выведен факт что стоковая широкополосная лямда после 13.0 а/ф даёт уже не точные показания смеси. Врет гдето на шесть десяток. Поэтому хондата рекомендует турбо- суперчаржер а также злые проекты атмо не отстраивать на стоковой лямде.что бы лямбда давала ему информацию и он подстраивался сам? машина RSX рестайл...
http://www.hondata.com/help/flashpro/index.html
DynoWheel = 472kW / 589 N.m
- Azazel
у меня стоковая лямбда очень сильно беднит мотор, датчик детонации постоянно моргает на 98 бензине....
я поставил вчера АЕМ, но к мозгу ее не подключал(родную отключил) и уже сейчас монитор показывает при 50% дроселя 14-15.5, а вот при 100% 11-13.5, холостые 14.0
Датчик детонации не разу не моргнул на АЕМке...
Почему нельзя что бы АЕМка работала вместо родной лямбды и есть ли смысл подключить обратно родную так как АЕМку я поставил вместо второй лямбды где труба из двух в одну сошла...
Последний раз редактировалось Azazel 26 май 2010, Ср 9:12, всего редактировалось 1 раз.
вместо.Azazel писал(а):просто повесить на него или вместо этого провода подключить?RRR писал(а):подключать один провод - белый.
E15 -ELD (Grn/Red)
вчера обнаружили такую хуйню на фн2 турбо, сток лямбда заливала мотор при небольшом нажатии на газ, с.трим убегал хуй знает куда.
- Azazel
так у меня наоборот бедная смесь, свечи белые... самое интересное у меня все лямбды в Хондате отключены...RRR писал(а):вместо.Azazel писал(а):просто повесить на него или вместо этого провода подключить?RRR писал(а):подключать один провод - белый.
E15 -ELD (Grn/Red)
- sniper
Такая же фигня была у нас в понеделник на TSX. Висела уже три лямды иновейтовская, аемовская и Д17. Орентир брал на иновейт потому как самая свежая, которая сразу показала богатую смесь как и аем. Д17 на оборот мего бедную Стрим шкалил. Чрез минут двадцать иновеит пошел к обеднению на аемке порежнему оставлось богата смесь. Попросил Андруху привезти нашего свеженкого бензина. После двацати минутной копоти все три лямды стали показывать одинаковое значения, после чего я закрыл петлю и по С трим вправил приблезительные карты. Через полчаса мы были уже в другом городе.RRR писал(а):вместо.Azazel писал(а):просто повесить на него или вместо этого провода подключить?RRR писал(а):подключать один провод - белый.
E15 -ELD (Grn/Red)
Значения А/Ф на круизных режимах не менялос так и оставалось от 14.2 до 14.7
- Mura
Azazel писал(а):а голубой провод куда подключать то??? Serial output?
на ноутбук
- Azazel
вооо ... Дим!!! проблема вот в чем... ты мне машину настраивал на своей лямбде и сказал что моя умерла, потом мою вкрутили и отключили в хондате, но она походу все равно работала так как смесь бедная была... я сейчас AEMку поставил, мне нужно в хондате включить первую лямбду или нет? и что получается, что синий провод просто будет болтаться без дела?
- Mura
Azazel писал(а):вооо ... Дим!!! проблема вот в чем... ты мне машину настраивал на своей лямбде и сказал что моя умерла, потом мою вкрутили и отключили в хондате, но она походу все равно работала так как смесь бедная была... я сейчас AEMку поставил, мне нужно в хондате включить первую лямбду или нет? и что получается, что синий провод просто будет болтаться без дела?
на синий забей, у тебя в ноутбуке все равно нет RS232 )))
не должна работать, вернее, это видно по логам , по тримам.
АЕМ тебе уж сказали, только логи можно смотерть. Просто прокатись и посмотри без всяких проводов , какая собственно смесь. Успеешь проводов накрутить
И логи посмотри по тримам
- Azazel
просто пока я родную лямбду не отключил у меня датчик детонации моргал даже на 98 бензине, а когда я отключил ее датчик сразу перестал моргать...при плавном наборе скорости 14-15.5, при тапке в пол 11-13.5, холостые 13.5-14.0
не загорится ли ЧЕК если я активирую лямбду в хондате?
Сейчас этот форум просматривают: Dot [Bot], Google [Bot] и 6 гостей
