Часто задаваемые вопросы
Roman
Сообщение 27 фев 2007, Вт 20:59
Open Bonnet
Remove intake cover
Pull Wiring harness out of little rubber clip thing
Loosen jubilee clip on throttle body
Unplug IAT sensor and pull out sensor from intake tubing
Remove rubber pipe from airbox end only, then remove vacumn pipe from intake tubing
Remove rubber intake pipe
Remove rubber bung and long bolt from air box
Disconnect bottom intake hose from airbox, remove two nuts that hold it to the slam panel and remove from engine bay
Remove 1 bolt and 1 nut that holds airbox on
Remove air box
Fit spacer
Carefully remove old pipe from orignal air box
DO NOT USE MONKEY FOR STEP 15 COS YOU WILL BREAK IT!
Fit silicon rubber thingy
Pick up AEM pipe and fit
Insert AEM pipe complete with filter and clamp to throttle body with jubilee clip
Reconnect vacumn pipe, you will need to remove the little metal thing first (1st pic) and return feed (2nd pic)
Insert IAT sensor into grommet in AEM pipe
Bolt the beast down!
Admire your work!
