Часто задаваемые вопросы
RRR
Сообщение 26 янв 2010, Вт 0:01
Block Choices
All have 2354cc of displacement and 87mm bore and 99mm stoke
K24A1 (PPA), CRV (LRD)
160hp @ 6000rpm / 162lb-ft @ 3600rpm
Redline: 6500rpm
Compression: 9.6:1
K24A2 (RBB),TSX (CL)
200hp @ 6800rpm / 166lb-ft @ 4500rpm
7100rpm
10.5:1
*K24A3 (RAA), Accord (03+ CM, 5th Gen V6 and Wagon CE)
160hp @ 5500rpm / 161lb-ft @ 4500rpm
6500rpm
9.7:1
*K24A4 (PZD), Element (YH)
6500rpm
9.7:1
Some info on the Cranks
Code -- Bore -- Stroke - rod length - crank throw - journals - weight
k20a - 86mm - 86mm --- 139mm ---- 43.18mm ---- 20mm --- 38lbs
k24a - 87mm - 99mm --- 152mm ---- 49.53mm ---- 20mm
RDX -- 86mm - 99mm ----- ? --------------------- 20mm
F22c - 87mm - 90.7mm - 149.65mm --------------- 24mm
F20c - 87mm - 84mm --- 153mm ------------------ 24mm
Stock deck height
K20 212mm
K24 231mm?
F20C 224mm
Conbustion Chamber volume
K24 53.5cc
K20A/A2 50.7cc
K20A3 48.0cc - from JE
F20C 53.6cc +/- 0.2cc
Bore
K20 86mm
K24 87mm
F20C 87mm
Stroke
k20 86.0mm
k24 99.0mm
F20C 84.0mm
F22C 90.7mm
H22 90.7mm
F22C 106.0mm (inline pro stroker)
*IPS offers 86mm, 88.5mm, 90.7mm, 93.2mm, 96.5mm, 99mm, 101.6mm stroke options for K24
Piston speed in feet per second @ 8,500 rpms:
B16 - 4,317 fps
F20c - 4,685 fps
K20 - 4,797 fps
B18c - 4,864 fps
B18a/b - 4,963 fps
H22 - 5,059 fps
H23 - 5,299 fps
K24 - 5,522 fps
Rod length
k20 139mm (5.473") (rod/stroke = 1.62)
k24 152mm (5.984") (rod/stroke = 1.54)
F20C 153mm (rod/stroke = 1.82)
F22C 149.65mm
H22 143mm (5.630")
Rod BE Diameter
K/H/F 51mm
Rod Journal width
K20/24 19.8mm (0.780") BE width
H22/F20 23.8mm (0.938") BE width
rod journal diameter
K/H 48mm BE
Will except K20 head (straight bolt on), yes/no and why.
K24A1 (crv) - yes
New Compression Ratio:
K24A2 (tsx) - yes
New Compression Ratio: Around 10.2:1 ?
*K24A3 (element) - no, valve clearance issues
New Compression Ratio: As stock cannot be used, compression depends on choice of aftermarket.
*K24A4 (accord) - no, valve clearance issues
K20/K24 hybrid info-
Stuff that dosen't work:
K24A4 Pistons, Oil Pan
Needed:
K24 Block (type dosen't matter, K24A2 (TSX) has oil squirters)
K24 Timing Chain + Guides
K24 Water pump
K24 Timing cover
K24 Headgasket
K24A2/A1 rods and pistons (or other aftermarket)
CRV Timing mount
K20 Head
K20 Oil pan, pump and chain (pump needs to be modified for the K24A4 oil pan)
K20 Crank baffle
K20 Alternator
K20 Thermo housing
K20 Starter
External Links:
K20/K24 Hybrid How-to Short Block with K20A2 VTEC Cylinder Head - Tech - Sport Compact Car Magazine
K20/K24 DIY(into a 7thgen, for basic info)- XproductionZ.com :: Ver. 3.0 - K20/K24 Swap into 7thgen Civic 2001-2005
K20 oil pump meets k24- K24a2 meets Type S Oil Pump w/pics(no 56k) - K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum
K-Series Wiki- Honda K engine - Wikipedia, the free encyclopedia
K24 Group Buy- Group Buy on K24a Fully built Blocks - K20a.org Spec - K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum
RRR
Сообщение 26 янв 2010, Вт 0:03
строкер и дестрокер, в середине страници таблица
http://www.k20a.org/forum/showthread.php?t=3775&page=7
Net_Prosto
Сообщение 26 янв 2010, Вт 0:48
дестрокер для того что бы добица большого RS?
RRR
Сообщение 26 янв 2010, Вт 8:30
Net_Prosto писал(а):дестрокер для того что бы добица большого RS?
да, чтоб крутить далеко.
Apple_Shampoo
Candyman
Сообщение 26 янв 2010, Вт 11:28
ого, это можно к20 сделать 2.3 ?
RRR
Сообщение 26 янв 2010, Вт 12:13
Apple_Shampoo писал(а):ого, это можно к20 сделать 2.3 ?
да, но не в этом суть, суть в R/S
