- Chechel
- Лелик Брауншвейгский
Есть новый брелок и ключ от RSX (шел с машиной). Хочу поменять, а то старый истерся весь! Кто-нить знает как его прошить? Надо к официалам ехать или есть какое-нить сочетание секретное?
Сигналка штатная.
Мои треки, видосы и последние новости тут: Squared Che Group
- evil_curier
- xxx squad
лучше к официалам
Игорь
RSX Type-S был
RSX Type-S был
обратись к 5элемент, у него вроде были раскладные брелоки.
Storing transmitter codes:
The codes of up to three transmitters can be stored in
the keyless receiver unit memory. (lf a fourth code is
stored, the code which was input first will be erased.)
NOTE: lt ls important to maintain the time limits
between the steps. Make sure the doors and the hatch
are closed.
1. Turn the ignition switch ON (ll).
2. Within 1 to 4 sec,, push the transmitter lock or
unlock button with the transmitter aimed at the
receiver under the audio unit.
3. Within 1 to 4 sec., turn the ignition switch OFF.
4, Within 1 to 4 sec.. turn the ignition switch ON (ll).
5. Within 1 to 4 sec., push the transmitter lock or
6. Within 1 to 4 sec., turn the ignition switch OFF.
7. Within 4 sec., turn the ignition switch ON (ll).
8. Within 1 to 4 sec., push the transmitter lock or
9. Within 1 to 4 sec., turn the ignition switch OFF.
10. Within 4 sec., turn the ignition switch ON (lll.
'l'1. within 1 to 4 sec.. push the transmitter lock or
12. Contirm you can hear the sound of the door lock
acluators.W ithin 1 to 4 sec..p usht he transmitter
lock or unlock button again.
13. Within 10 sec., aim the remaining transmitters (up
to two auditional ones) whose codes you want to
storea t the receiver,a nd presst he transmitterl ock
or unlock buttons.
Coniirm that you can hear the sound of the door
lock actuators after each transmitter code is stored.
14. Turnt he ignitions witchO FF,a ndp ullo utlhekey.
15. Confirm proper operation ofthe transmitters.
22-165
are closed.
or unlock buttons.
22-165
RSX Type S
- evil_curier
- xxx squad
чет я тупанул про ключ подумал!!!!evil_curier писал(а):лучше к официалам
а че корпус просто нельзя поменять!!!
Игорь
RSX Type-S был
RSX Type-S был
- Chechel
Корпус поменять? Не знаю стоит ли так морочиться ))) Попробую схему в посте выше. Потом отпишу че-как!evil_curier писал(а):чет я тупанул про ключ подумал!!!!evil_curier писал(а):лучше к официалам
- NiTRO
попробуй, у меня тоже есть новый брелокChechel писал(а):Корпус поменять? Не знаю стоит ли так морочиться ))) Попробую схему в посте выше. Потом отпишу че-как!evil_curier писал(а):чет я тупанул про ключ подумал!!!!evil_curier писал(а):лучше к официалам
хоче сменить
продаю запчасти для хонды
- Chechel
Слушай, ну в общем, не стал я париться - вскрыл брелок за 5 секунд, перекинул старую плату в новый корпус и все в поряде! Там где колечко есть отверстие, туда отверточку часовую или ножичек и все открывается очень просто! Так что дерзай!NiTRO писал(а):попробуй, у меня тоже есть новый брелокChechel писал(а):Корпус поменять? Не знаю стоит ли так морочиться ))) Попробую схему в посте выше. Потом отпишу че-как!evil_curier писал(а):
хоче сменить
- NiTRO
))Chechel писал(а):Слушай, ну в общем, не стал я париться - вскрыл брелок за 5 секунд, перекинул старую плату в новый корпус и все в поряде! Там где колечко есть отверстие, туда отверточку часовую или ножичек и все открывается очень просто! Так что дерзай!NiTRO писал(а):попробуй, у меня тоже есть новый брелокChechel писал(а):
хоче сменить
