MF
повелитель молдавского втека
Сообщение 18 янв 2009, Вс 12:17
Наконецто Хондата победила.
http://hondata.com/kpro_dual_ecu_tsx.html
Package consist of:
* A K-Pro fitted to a Hondata or user supplied compatible ECU
* The dual adapter cable
* Reflashing your stock ECU
Compatible Vehicles:
* 2004-2006 K24 US market Acura TSX Manual with ECU part # 37820-RBB-A02-A05
* 2004-2006 K24 US market Acura TSX Auto with ECU part # 37820-RBB-A54-A61
Requires:
The K-Pro requires an Air-Fuel ratio sensor from a US 2002 D17 Civic (Part # 36531-PLR-003) as the stock sensor is incompatible.
Main features:
* Factory reliability for your TSX.
* Easy starting.
* Dash water temperature display functions normally.
* All the features of the K-Pro:
* Injector re-calibration.
* Fully mapped boost tables.
* Nitrous control.
* Datalogging.
* Boost control.
* And more...
The stock TSX ECU limits the cam advance to 20 degrees. (even though the mechanism is capable of 25 degrees) By machining the VTC mechanism to allow 45 degrees of advance and using the K-Pro you can pick up torque throughout the rev range, especially if you have an intake and headers.
The following graph is a test of a stock ECU followed a few minutes later by a tuned K-Pro in an internally stock 2004 TSX. For both tests the TSX is equipped with identical bolt-ons:
* Injen intake
* Hytech headers,
* High flow cat,
* Hytech exhaust
* Green line is K-Pro tuned with the dual adapter harness (3600 rpm vtec point)
* Pink line is stock ECU
Ценнег правда немного не радует
Price Description
$1995* 04-06 Dual adapter harness & K-Pro installed in new ECU.
$1395* 04-06 Dual adapter harness & K-Pro installed in user supplied ECU.
$495* 04-06 Dual adapter harness User supplies K-Pro & ECU
Honda-Racing
Почетный член клуба
Сообщение 18 янв 2009, Вс 12:39
nemnoga uze v drugom razdele temu etu obsuzdali
Тел.+37258504763
Skype. honda-racer
Speedy
Сообщение 18 янв 2009, Вс 13:23
Honda-Racing писал(а):nemnoga uze v drugom razdele temu etu obsuzdali
+1
было было!)))) давненько!))))
MF
Сообщение 18 янв 2009, Вс 15:36
Пардон..На хондатече обнаружил..
А тут не заметил где обсуждали..Хотя как такое могли здесь пропустить :D
Honda-Racing
Почетный член клуба
Сообщение 18 янв 2009, Вс 18:18
ti sebe uze zakazal ??
Тел.+37258504763
Skype. honda-racer
felix
Сообщение 18 янв 2009, Вс 22:11
Давай заказывай, в Америке уже во всю К-Про впаивают... У меня моск от ТСХ пылиться... Ждет своей участи...
Типа подпись!
MF
Сообщение 18 янв 2009, Вс 22:21
Нет..Размышляю нужен ли мне круиз :D Но чета склоняюсь что не нужен :twisted:
alexei-cars
Сообщение 19 янв 2009, Пн 9:49
MF писал(а):Пардон..На хондатече обнаружил..
Да нафиг он тебе нужен?!!!
Acura TSX- моя красавица
Honda Civic TypeR- машина жены
Mazda MPV 3.0 V6- быстрый автобус (тоже мой)
felix
Сообщение 19 янв 2009, Пн 10:17
Я им только после покупки попользовался, и все 1 год не пользуюсь, автобанов таких нет.
Типа подпись!
rchip
Пушкин клуба
Сообщение 19 янв 2009, Пн 11:50
а я как нить на ультитмате за 15 кусков поезжу...
MF
Сообщение 19 янв 2009, Пн 13:30
Впору TSX Squad делать :twisted: :lol:
