Часто задаваемые вопросы
.Серый.
Сообщение 03 окт 2008, Пт 11:49
Изображение 2002-04 Acura RSX
Stock Weight - 2694lbs [1201 кг.]
Stock Wheel Weight - 16lbs each/without tires [7.26 кг.]
The 2002-04 Acura Integra's weigh approximately 2694lbs, dividing by the horsepower of 160, we get about 16.84lbs/hp.
The Type S Model weighs approximately 2767lbs, dividing by the horsepower of 200, we get about 13.83lbs/hp.
What this basically means is that for every 13.83 pounds of weight removed from the car we should achieve the equivalent of a 1hp increase. There are many things that can be lightened on the RSX so gains here should be easy to achieve.
Listed below are some easily removable items:
1. Passenger Seat (37lbs) [16,7 кг.]- Removing the passenger seat is a very easy and effective way to give your RSX a small boost in power. The nice thing is that the seat is only held in place by 4 bolts.
2. Rear Seat (29lbs) [13.1 кг.]- The rear seat is a little more complicated to remove than the passenger seat. When removing just remember where everything goes and it should be easy to put back in place whenever needed.
3. Rear Seat Cushion (10lbs) [4.5 кг.]- The rear cushion should be removed at the same time as the rear seat.
4. Floor Mats/Front and Rear (6lbs) [2.7 кг.]- This has to be the easiest weight reduction available for the RSX owner!
5. Tire Floor Cover (3lbs) [1.3 кг.]- The tire floor cover is right underneath the rear hatch carpeting.
6. Spare Tire and Jack (32lbs) [14.6 кг.]- Another easily removable item.
Total Easy Weight Removal = 117lbs [53 кг.]or about a 6.9hp increase on base , 8.46hp increase on Type S.
Intermediate Skill Weight Reductions
The weight reductions included below can even prove more effective than some of the reductions included above. However, once you start removing these items you are taking away from the cars overall appearance and in some cases its more predominent ammenities.
7. Air Conditioning (40lbs) [18.1 кг.]- Removing the air conditioning will net you a reduction of about 40lbs. Be sure to remove everything from the engine as well as behind the dash. Should be completed by the experienced only.
8. Front Hood (50lbs) [22.65 кг.]- Replacing the Front Hood with a lightweight fiberglass or carbon fiber hood is a great way to remove some weight around the front end of the car. Total weight reduction will be close to 50lbs or greater depending on the aftermarket hood you choose.. If you dont intend on replacing the entire fron hood you could also remove the sound dampener on the inside of the hood. This should help in cooling your engine a little.
9. Stock Wheels (16lbs each/replacement weight from 11lbs each) - Replacing the wheels is a must for anyone seriously interested in increasing there cars performance. The stock wheels are quite heavy and can be replaced with a variety of aftermarket models. We would suggest searching for lightweight wheels. Replacing your wheels with lightweight wheels will dramatically increase your cars acceleration. We suggest not going over 17 inches if maximum performance is what you desire to achieve.
10. Front Drivers Seat (40-60lbs/replacement weight from 14lbs) - Replacing the two front seats in your RSX with lightweight racing alternatives can save you a dramatic amount of weight. We suggest going with lightweight carbon fiber or fiberglass seats.
Total Intermediate Weight Removal = up to 188lbs or a 11.2hp increase on base, 13.6hp increase on Type S.
More Weight Reductions
Stock Flywheel - Can be replaced with lightweight aluminum flywheels or machined down in excess of just 10lbs.
Stock Steering Wheel - Can be replaced with lighter performance steering wheel with no airbag.
Passenger Airbag Removal - Can save some extra weight as well. (Not recommended for normal driving)
Interior Panels - Both the drivers side and passenger side front door panels as well as the rear panels can be removed to save in excess of over 40lbs.
Stock Speakers - With a weight of over 2 pounds a piece these can also be easily removed. The power antenna as well as the stock stereo and amplifier can also be removed to save weight.
Rear Hatch Cover - This can simply be removed whenever needed. Weight is close to 6 lbs.
Replace Stock Exhaust - The stock RSX exhaust weighs considerably more than some of the aluminum aftermarket exhausts. We suggest going with GReddy Cat back exhaust or Borla Cat back.
Wiper Motors - Although they are generally needed under almost all driving conditions they CAN be removed if need be although we do not personally recommend it.
Carpet - Removing the carpet as well as the carpet lining underneath will reduce the cars overall weight by close to 40lbs. Removing excess wiring and bolts and brackets will also net you a reduction of close to 10lbs.
взято отсюда
.Серый.
Сообщение 03 окт 2008, Пт 13:56
md013 писал(а):Я вот с пиндосовским не дружу, может кто переведет или скажет чего сколько в итоге?
кресло пассажирское, ковер, задний диван и запаска с домкратом - 53 кг.
Azazel
Сообщение 13 окт 2008, Пн 11:59
я вот знаю, что люк крыши со всеми салазками около 50кг весит... а на DC5 его нет...
=Fly=
Машина: Dc5 k24
Сообщение 03 июн 2015, Ср 20:02
Azazel писал(а):я вот знаю, что люк крыши со всеми салазками около 50кг весит... а на DC5 его нет...
да нету там столько)
dropdead
Машина: K24 DC5 AT
Сообщение 07 июн 2015, Вс 22:12
около 20 он весит.
=Fly=
Машина: Dc5 k24
Сообщение 07 июн 2015, Вс 23:52
около 20 он весит.
14.35 со стеклом
Сейчас этот форум просматривают: Dot [Bot] и 1 гость
