uRzza
Сообщение 10 сен 2008, Ср 8:11
Кто сталкивался помогите разобраться с этой приблудой. на сколько я знаю должна смещать момент срабатывания втека. Если нужны фотки это приблуды завтра выложу. мое Авто accord euror cl1 h22a
TA6
Сообщение 14 май 2009, Чт 13:07
uRzza писал(а):Кто сталкивался помогите разобраться с этой приблудой. на сколько я знаю должна смещать момент срабатывания втека. Если нужны фотки это приблуды завтра выложу. мое Авто accord euror cl1 h22a
Нашел мануал на модель с MIVEC, но общая тема настройки я думаю раскрыта. Сижу вкуривую.
Overview.
The R-SPEC MIVEC controller from Data Systems in Japan is an after-market device (ie not fitted as standard) that has three memories to allow the user to alter the RPM at which the engine switches from its low cam to high cam settings. Two of these settings are user controlled - the third is the factory "Normal" setting. By changing the switching points, you can alter the driving characteristics of the MIVEC engine. It can give the feeling of a more natural rise of the MIVEC engine power. The controller can also give an audible RPM limit warning and delimit the top speed of the car. It also has a Stopwatch facility, a clock and an time alarm.
A worthwile addition to any MIVEC car !!
Setting the time.
Press the Function Select and Down buttons at the same time - until hh:mm is displayed.
Note the : should be flashing, hh=Hour and mm=minutes.
Press the Function Select button.
Then use the Up or Down button to set the hour.
Then ress the Function Select button again.
Then use the Up or Down buttons to set the minutes.
Setting the Alarm.
Press the Function Select and Down buttons until the time is displayed.
You can now toggle between the time and viewing the alarm setting by pressing the Down button.
To change the alarm setting -
Toggle to the alarm view and then press the Up and Down buttons at the same time.
Press the Function Select button and then alter the hour using the Up or Down button.
Next press the Function Select button and then alter the minutes using the Up and Down button.
The alarm is toggled on or off by pressing the Up button whilst on the time display.
A . is shown between the minutes when the alarm is on.
Setting the RPM limit.
This does not electronically limit the RPM ceiling - just gives an audible warning at the set RPM.
Press the Function Select button - unitl the SU:nn (where nn is the current RPM ceiling - 65 = 6500 RPM) setting is displayed.
The RPM indicator (Bottom right of digital display) will light.
Press the Up or Down buttons to set the RPM ceiling.
Setting the MIVEC points.
Press the MIVEC/Cam Select button.
On each consecutive press (within 3 seconds) you should see a H1, a H2 and an - no - setting.
They will look like H1:36 or H2:55 or - no -
The first two digits are the Cam setting - H1 = User memory area 1, H2 = User memory area 2 and - no - = Factory setting.
The second two digits are the RPM setting - 36=3600RPM, 55=5500RPM - This is the RPM point at which the MIVEC system will change to the next cam setting.
To change the RPM setting at which the MIVEC changes - on the H1 or H2 option the RPM setting can be changed by pressing the Up or Down buttons until the desired RPM setting is achieved.
What you set these points to will depend on your driving style - EXPERIMENT !!!!
Using the stopwatch.
Press the Function Select and Down buttons at the same time - until the display shows 00.00 and the Stopwatch indicator light (Top right of digital display) is lit.
Press the Up button to stop and restart the Stopwatch.
Press the Down button for Split/Lap timing.
Hold the Function Select button down for 3 seconds to reset the stopwatch to 00.00
Other Functions
There are 5 more functions.
They are accessed by holding down the Function Select button whilst on the RPM display.
They are altered using the Up or Down buttons.
The functions are -
C This referrs to the number of cylinders in the engine. It has settings of 0 to 16 This should be set to C - 6
P I am told, by the manufacturers, that this has something to do with "Speed pulses" - and should be left at 4.
This has a value of 2,4,8,or 16 The Standard setting is P - 4
Adnn This setting allows you to match the RPM shown on the unit with that shown on the Rev counter.
nn has a value of 1.30 to 0.70 The default setting is Ad00
H-nn This sets the speed at, above which, the MIVEC system starts to work.
Where nn has a value of 0 to 99 The Standard setting is H - 30
b-nn This turns the "Beep" on/off - The Standard setting is b - on
Hints
Want higher MPG - set MIVEC to come in at 99 MPH or above 9000 rpm
+ EVO 9 MR +
+ Honda S2000 AP1 +
+ Honda FIT RS CVT +
PRODRIVE
Машина: 4M51
Сообщение 17 май 2009, Вс 14:07
Ха,тоже искал мануал,но в итоге выкинул эту приблуду.Она ни чего не умеет,кроме как пищать.Особого смысла в двигании втека не вижу.
http://images.google.co.uk/imgres?imgur ... N%26um%3D1
JAPANCAR.RU
ecko1972
Сообщение 06 сен 2020, Вс 14:46
Привет. Столько лет прошло. Удалось разобраться? Какой вообще PiggyBack лучше всего для cl1 EuroR ?
Я пока разбираюсь с AFC NEO. Вроде он самый продвинутый...
Sergey34
Сообщение 07 сен 2020, Пн 0:01
Таким гаджетам пора уже в музей в 2020м году :D Купи флеш про или что там надо,и кайфуй.
В пупуасиях всяких до сих пор строят турбо Д,на Вафк апекси,капец :D за изобретение конечно пять,за идею неуд)
Сейчас этот форум просматривают: Dot [Bot] и 24 гостя
