Нашел на англоязычном сайте инфу по поводу хондаты, что якобы, датчик масла при установки сие оборудования перестает работать!Испугало, так как, к сожалению не имею привычки залезать под капот дабы проверить мало!Правда ли это?
вот ссылка http://type-r-owners.co.uk/forums/showt ... hp?t=52822
Fitted the Hondata Group N ECU today, as supplied by CPL Racing. Certainly not as flexible as our EP3 brethren's Kpro, but as availablilty is thin on the ground, thought I would give it a shot.
CPL delivered it special delivery and it took 15 minutes to fit. A simple plug and play affair.
The parameters that have been changed are:
* The VTEC point has been lowered to 3800 RPM
* There is a VTEC window in place between 3800 - 5200
* Rev limit raised to 8600 RPM
* Secondary Oxygen sensor has been disabled. (To allow race headers)
* Oil level indicator has been disabled. (Not sure why?)
* Ignition timing has been advanced
* Cam angles optimised for better breathing
Bad Points:
Initially, I was not pleased with the ECU, as my car sounded quieter at idle, and had lost a little of the burble that I like.
The inbuilt limiter preventing > 4000 rpm (stationary/neutral) has gone, found this as I started the car. I had just completed a 30 mile trip so the car was warm, so I blipped the throttle to see if the exhaust not changed and it zotted off past 5k. Ooops - will have to remember that.
Loss of the immobiliser.
Good Points:
OMG! OMG! OMG! OMG! OMG! OMG! OMG!
A cracking increase of torque felt, pulling much harder from idle through the entire rev range. 8600, feels like a cushion limiter, just dipping it by about 200 rpm, when it hits. Not vicious but gradual. There seems to be a bit more urgency in the way the the REV counter swings around, heading towards the redline whilst under acceleration and the Speedo backs this up, with 100 being achievable in third. (Simulated Driving: Other vehicles may deviate from said figures - Don't try this at home and not on a public highway - End of Disclaimer).
Now, I was quite concerned as to what would happen with the new ECU, when I hit the 3900 point. In respect of what speed I would be doing in top, and would it interfere with the cars normal cruise control speed. I know the car is not tuned for economy but I didn't want it to be sat in the VTEC continuously.
This is cleverly, where the VTEC window comes in. The VTEC window allows you, anywhere between 3800 and 5200 to press the throttle, and immediately be in the VTEC range, all the way through to 8600. But if you wanted to cruise at say, 4000 rpm, the VTEC will disengage. It senses the application of the throttle to either switch in or out of the VTEC. It does this anywhere within the VTEC window, giving you some sort of economy.
Not yet driven the car in anger, but on the whole it feels beefier and more responsive, and the VTEC wail goes on... and on...... and on................
Bad Points:
Good Points:
Еще очень интересует вопрос, датчик витека после установки будет включаться с 3800RPM или по старинке с 5600?)
При 100% дросселя с 3900 при 50-75% в районе 5000
СTR - 07
СTR - 07
А с датчиком малса что?
Не будет работать датчик уровня масла, не путать с давлением масла!
Надо просто масло будет по щупу проверять и все!
СTR - 07
СTR - 07
То есть, если в прошлый раз, когда я ехал на машине и мне на борт комп вылезло сообщение low oil или что-то вроде того , то теперь такого не будет,так?0)
Да именно так ! Раньше такого на хондах и небыло никогда, лучше все равно по щупу смотреть!
СTR - 07
СTR - 07
Понял, спасибо) ! Первый раз имею дело с хондой)
- Василий58
- ЗЛОЙ КОЛХОЗНЕГ НА ЕВРЕЕ
а фн2 все-таки прогресс, он мне начинает нравится
Производители хондаты не хотят случайно баг убрать с лампочкой уровня масла?
CTR FN2
hondaracer
Имхо когда лампочка зажигается-это уже практически засаженный мотор...Если хочешь катать на быстой хонде-проверка уровня масла раз в 2 дня стабильно...У меня это уже вошло в привычку...
- temper
- да ты успокооООйся
- Машина: чорный мокасин
маленький моторный отсек! фиг куда дотянешся тюнерскими ручонками. чтоб поставить ксенон придется скинуть бамперВасилий58 писал(а):а фн2 все-таки прогресс, он мне начинает нравится
http://coub.com/vsenormalno
Я не снимал! все стоит отлично, блоков не видно
СTR - 07
СTR - 07
Я видел как мне его снимали, там ничего сложного...
Я на преле постоянно проверял, а на сивке порой забываю, у меня за 7,5тыс подъело 300грhondaracer писал(а):Имхо когда лампочка зажигается-это уже практически засаженный мотор...Если хочешь катать на быстой хонде-проверка уровня масла раз в 2 дня стабильно...У меня это уже вошло в привычку...
CTR FN2
hondaracer
Может кирпич под правой педалью?Posol писал(а): Я на преле постоянно проверял, а на сивке порой забываю, у меня за 7,5тыс подъело 300гр
Да не к20 просто не жрет особо, у меня расход литр на 5000-6000 тыс
СTR - 07
СTR - 07
Не совсем. Повседневная езда на 4т об, а так 7-8 об переключения, когда быстрее надо часто в отсечку упираюсь.hondaracer писал(а):Может кирпич под правой педалью?Posol писал(а): Я на преле постоянно проверял, а на сивке порой забываю, у меня за 7,5тыс подъело 300гр
Насчет 7,5 тыс наврал, я масло на 5,5тыс менял - проверил расход 300гр
CTR FN2
