Часто задаваемые вопросы
.Серый.
Сообщение 15 май 2008, Чт 7:39
принципы работы
ТТХ
K20A
Found in:
2001-2005 Honda Civic Type-R (EP3)
Displacement: 1998 cc
Compression: 11.5:1
Power: 212 hp (215 PS, 158 kW) @ 8000 rpm
Torque: 149 ft·lbf (202 N·m) @ 7000 rpm
Redline: 8400 rpm
2001-2006 Honda Integra Type-R (DC5)
Compression: 11.5:1
Power: 217 hp (220 PS, 162 kW) @ 8000 rpm
Torque: 152 ft·lbf (206 N·m) @ 7000 rpm
Redline: 8500 rpm
2002-2006 Honda Accord Euro-R
Compression: 11.5:1
Redline: 8500 rpm
K20A2
Found in:
2002-2004 Acura RSX Type-S and 2002-2005 Honda Civic Type R (EP, European)
Compression: 11.0:1
Power: 200 hp (147 kW) @ 7400 rpm
Torque: 142 ft·lbf (193 N·m) @ 6000 rpm
Redline: 8200 rpm
K20A3
Found in:
2002-2005 Honda Civic Si
Compression: 9.8:1
Power: 155 hp* (119 kW) @ 6500 rpm
Torque: 139
2002-2006 Acura RSX
Compression: 9.8:1
Torque: 139 ft·lbf* (191 N·m) @ 4000 rpm
Redline: 6800 rpm
(* Horsepower and torque calculations reflect new SAE J1349 procedures revised August 2004)
K20Z1
Found in:
2005-2006 Acura RSX-S
Compression: 11.0:1
Power: 201 hp (150 kW) @ 7800 rpm (sae NET Rev 8/04)
Torque: 140 ft·lbf (194 N·m) @ 7000 rpm (sae NET Rev 8/04)
Redline: 8200 rpm
K20Z2
Found in:
2006- Acura CSX (Canada)
Compression: 9.6:1
Power: 155 hp (114 kW) @ 6000 rpm (sae NET Rev 8/04)
Torque: 139 ft·lbf (188 N·m) @ 4500 rpm / 188 N·m @ 4200 rpm (Singapore)
Redline: 6800 rpm
2006- Honda Civic (JDM)
Compression: 9.6:1
Redline: 6800 rpm
2006- Honda Accord Sport(Europe)
Compression: 9.6:1
Redline: 6800 rpm
K20Z3
This inline-4 cylinder internal combustion engine is found in the redesigned Honda Civic Si. It has an aluminum block with aluminum heads, and a bore and stroke of 86 mm*86 mm, resulting in a 2.0 Liter displacement.
Found in:
2006+ Honda Civic Si
2007 Acura CSX Type-S
Displacement : 1998 cc
Compression : 11.0:1
Power: 197 bhp (147 kW) @ 7800 rpm (sae NET Rev 8/04)
Torque: 139 lb·ft (189 N·m) @ 6200 rpm (sae NET Rev 8/04)
Redline: 8000 rpm
K23
K23A1
Turbocharged
Found in:
2007 Acura RDX
Displacement: 2300 cc (acura.com)
Compression: 8.8:1 (acura.com)
Power: 240 hp @ 6000 rpm (SAE net)
Torque: 260 ft·lbf @ 4500 rpm (SAE net)
Redline: 6800 (acura.com)
Bore: 86 mm
Stroke: 99 mm
K24
K24A1
Found in:
2002-2006 Honda CR-V
Displacement: 2354 cc
Bore and Stroke: 87 mm x 99 mm (3.43x3.90 inches)
Compression: 9.6:1
Power: 160 hp (119 kW) @ 6000 rpm
Torque: 162 ft·lbf (220 N·m) @ 3600 rpm
Redline: 6500 rpm
K24A2
Found in:
2004-2006 Acura TSX
Compression: 10.5:1
Power: 205 hp (149 kW) @ 6800 rpm
Torque: 166 ft·lbf (225 N·m) @ 4500 rpm
Redline: 7100 rpm
K24A3
Found in:
2003-2006 Honda Accord (Europe, Japan, and Australia)
Compression: 10.5:1
Power: 189 hp (140 kW) @ 6800 rpm
Torque: 164.5 ft·lbf (223 N·m) @ 4500 rpm
Redline: 7000 rpm
K24A4
Found in:
2003-2005 Honda Accord, 2003-2006 Honda Element
Compression: 9.7:1
Power: 160 hp (119 kW) @ 5500 rpm
Torque: 161 ft·lbf (218 N·m) @ 4500 rpm
Redline: 6500 rpm
K24A8
Found in:
2006/2007 Honda Accord
Compression: 9.7:1
Power: 166 hp (124 kW) @ 6000 RPM
Torque: 160 ft·lbf @ 4000 rpm
Redline: 6500 rpm
temper
да ты успокооООйся
Машина: чорный мокасин
Сообщение 30 авг 2008, Сб 2:26
K20Z4
Found in:
2007 Honda Civic Type-R (FN2) (Europe Market)
Power: 197 bhp (201 PS, 148 kW) @ 7800 rpm
Torque: 142 ft·lbf (193 N·m) @ 5600 rpm
Redline: 8200 rpm
http://coub.com/vsenormalno
Сейчас этот форум просматривают: нет зарегистрированных пользователей и 0 гостей
