- gonsalez
- Машина: FD2R
я ошибся, чтобы рычаг нижний был погоризонтальнее.
Roll center adjusters help to maintain proper steering alignment and suspension geometry on lowered cars. If you have lowered your car these are a must have to keep it handling the best.
Old worn and tired bushings will drastically reduce the feel and handling of your car. Replacing worn bushings and suspension components can really make an older car feel new again. Our rubber bushings feature a stiffer durometer than OEM and are designed to last. Spherical bushings are perfect for race cars that need solid but smooth movement of suspension components.
By extending the ball joint on the front lower control arm, the Buddy Club P1 Racing Ball Joint raises the roll center and brings it closer to the center of gravity, thus increasing the vehicle's roll stiffness and eliminating any unwanted side effects to the vehicle's suspension geometry.
dc2R>dc5R>dc2R>cl7R>dc5R>fd2R
- koha
- Машина: nissan silvia s13 sr20vet
xxx e81 130d n57(350hp/700nm) - Откуда: Кемерово-Москва
Речь не об этом. Занижая рычаг ты нарушаешь параллельность с рулевой тягой И получаешь уебка с диким паразитным подруливанием, который рыщет по колеям и разметке. Ну чистая гонка. А потом ебешь всем голову, какие диски выбрать
АДМ 1:49.7
Смоленск 1:42.0
Нринг 1:45.8
КК 1:09.3
MRW 2:09.5
- MrDracon
- Машина: RSX'S 05
кстати, не знаешь, такая история только на dc5, или на ep3 та же проблема?gonsalez писал(а): ↑я ошибся, чтобы рычаг нижний был погоризонтальнее.
Old worn and tired bushings will drastically reduce the feel and handling of your car. Replacing worn bushings and suspension components can really make an older car feel new again. Our rubber bushings feature a stiffer durometer than OEM and are designed to last. Spherical bushings are perfect for race cars that need solid but smooth movement of suspension components.By extending the ball joint on the front lower control arm, the Buddy Club P1 Racing Ball Joint raises the roll center and brings it closer to the center of gravity, thus increasing the vehicle's roll stiffness and eliminating any unwanted side effects to the vehicle's suspension geometry.
RSX-S.
- purple
- Машина: На ходу
А, точно так я и задумался!))
Посмотрел в его теме про коробку номерки. Спросил сказали на дц5 дорест подходит. Надо как-то планировать. Новьё, со влётом под 50 без работы...
Кароч пока решил место поменять, там гляну.
- Gree.VTEC
- Машина: DA5
Дак и рулевой наконечник гоношники переносят вниз под сошку.
И, насколько помню, шарами на сильном занижении как раз и отыгрывается разница положений тяги и рычага, что они начинают работать как на сток высоте.
Данным давно это обсасывалось всё, уже не вспомню точных деталей.
- koha
Гриш, ты матвею бы объяснил, что надо сошки переварить на его новых бц, 99% так не делают
АДМ 1:49.7
Смоленск 1:42.0
Нринг 1:45.8
КК 1:09.3
MRW 2:09.5
- Матвей
- лютый
koha писал(а): ↑Гриш, ты матвею бы объяснил, что надо сошки переварить на его новых бц, 99% так не делают
какой нахуй бц - !! у меня КВ Клабспорт на мегле стоит
а на дс5 стояли и длинные шары и вставка на рулевую рейку и рулилась она идеально
Последний раз редактировалось Матвей 08 ноя 2020, Вс 1:00, всего редактировалось 1 раз.
впуски Gruppe MО
привезу с японии и америки
спортивные подвески
Tegiwa
Hardrace
VK http://vk.com/club46769951
спортивные подвески
Tegiwa
Hardrace
- Матвей
- лютый
ты это делал чтобы схождение вернуть так как резьбы не хватило бы !! но это вовсе другая тема нежели длинные шары
впуски Gruppe MО
спортивные подвески
Tegiwa
Hardrace
спортивные подвески
Tegiwa
Hardrace
- ishitmykidney
- Машина: Мона Лиза
Божественный поджоп - Откуда: Дефолт Сити
Без сильного занижения нахуй не надо с этим играться. На сильном наверное есть смысл. А может и нет. Я ставил разницы не заметил.
Автору сил в восстановлении) пол на ней в печальном состоянии, и арки бы сделать нормально цельными кусками.
we `ll bang, ok?
ishitmykidney непроизносимый.
Dr1fta недостижимый.
qwerty именованный.
Хуяксимус непобедимый.
Заебал репрессированный
ХУяксимусом возвращенный
Повелитель песочницы.
qwerty именованный.
Сейчас этот форум просматривают: Bing [Bot] и 21 гость
