Typical Street motor that is built making around 200 WHP. This is a 84 MM GSR motor, with a dome JE piston.
This is not just swapping out cams and seeing if it is better. This is ROM tuning for EACH cam to achieve close to the best results.
Take a look at the graph below here. This is the fully tuned Skunk Type 2 motor, showing the first pass on the Toda D's. After 10+ runs of rom tuning it and
Adjusting the cam gears in every direction, 18+ WHP was netted in areas. Whenever you buy big cams, be prepared for hours and hours of dyno time.
